Crankshaft Position Sensor
LikeAnEclipse
Dec 21, 2010
Chrisman, Illinois
Which wire on the CSP Sensor do I splice my tach wire into for aftermarket tach. The Black and Red, Blue and White, or Yellow?
None, you're best off to tap into pin #73 on the ECU which is the outputted tach signal, or tap into that wire near the gauge cluster.
As long as you have the 2.0 and not the 2.4. Thats the wire Pin 73.
As you can see in the pick your PCM is is the in front of the left strut tower.
This stuff is complicated haha. I'll have to see if one of my friends can find that for me so I don't mess it up. But those diagrams helped alot! Thanks
Thanks Stone after i looked around for a bit i got it all hooked up. It works now and is not a notch off. The only thing i gotta do to get it completely done is to figure out why the switch i put on it keeps blowing its fuse
