black12
- 83
- 0
- Aug 21, 2004
willingboro,
New Jersey
im doing a stock rebuild on a 6 bolt motor. i have the motor out on the engine stand. i just put new main bearings in. i lubed the bearings and layed the crank back in the block. it spins real smooth and easy. but when i put on the main bearing caps on and turn the crank its too hard to turn.. it turns but i takes too much strength. and this even before i toque down the main bearing caps. ive tried prying the crank from end to end to alighn the thrust bearing. did i do something wrong. ?
