Crankshaft bolt hole slightly stripped
Twistedhellion2
Jun 7, 2011
Mechanicsburg, Pennsylvania
Ok so when we were refastening the flywheel to the crank on my 420a we over torqued one of the bolts and its only got about 70-80 lbs of torque cause it stripped out a coil or two in the crank...should it still be ok with all the other 7 bolts holdin it in there strong at close to 100lbs?
Out of safety I would recoil it and torque it back down. My cousins datson pickup truck was a victim of not using all the flywheel bolt and it came flying out :(
Daily beater and I asked my buddy he had the final read and it had atleast 90lbs on it still so I should be ok right?
Are you referring to the 8 bolts that fasten the driveplate to the crankshaft (opposite end of the damper pulley)? The torque spec for those 8 bolts is only 70 lbs/ft - not 100 lbs/ft.
Yes. I read that it was 100 ft/lbs on a thread a few days ago. Will the extra torquing be anything to worry about? I'm not extremely car savvy.
