Crank walk question
750_sport
70
Feb 17, 2005
Sacramento, California
I have read alot here so far, Nice Site!
When this is going on, can you see the crank pully move back and forth? Or is there to much damage to run by then?
Also. I heard mitsu was fixing these motors?
Thanks
michael
This is not a problem with non turbo motors. It happens in 7 bolt 4g63's, mainly the 2g motors. Although I did have a my freshly rebuilt block walk(1g 7bolt).You will most likely not be able to see the crank pulley move, if that is happening most likely there is a bad harmonic dampener on the pulley itself.
Rob :dsm:
