Crank Pulley Shaking
thejones
Dec 12, 2010
Long Island, New York
The belt from the alternator to the crank was making some noise. I can see its from the crank pulley shaking a bit. Is there a remedy for this. All the other pulleys are pretty solid.
thanks
I doubt it's the crank pulley. Maybe tighten the pulley to required torque specs? Are you really sure it's the crank pulley cause that would effect your power steering/AC belt too? More info/investigation (on your part) needed please :D
I'll try to re torque it...the other belt is fine. I'll look around some more.
Thanks
