2G Crank over once but no start
Sammy cruz
May 2, 2023
Corpus Christi, Texas
I'm new to DSMs, I have 2g talon with a 6 bolt swap and I am running into an issue of where the car is cranked over and sounds like it’s about to start but doesn’t.
Now when the car is cold it will crank right up and sound like it’s running weird, but after about 5 mins of the car running it will shut off and not start back up until it cools down again. I’ve already changed plugs, wires, CAS, and power transistor.
Before the problem occurred I was driving and sometimes the car would cut out and then cut back in, and even shut off at times. Any advice helps
