97egl
- 873
- 564
- Feb 6, 2014
Brownsburg,
Indiana
What is the most endplay a 1g 7bolt crank can have before it is too bad to use again? I bought a used engine and am wanting to use the crank out of it. It has .010 endplay. Spec says .002-.007 but not sure if that for on a new engine
Here's the long story.
I built a 7 bolt N/A engine for enduro racing. (Enduro= 300 Laps on 3/8 asphalt or dirt track with 100+ cars.)
I did all new seals and gaskets, head studs, as well as Race Main and Rod bearings. I also did the balance shaft removal. Ran 15w-40 diesel oil which is pretty standard to do as the oil thins out when the engine temp is staying around 210
I made 24 laps and the #4 rod bearing spun so bad it locked the motor up. So I need a new crankshaft and I couldn't find one for a decent price so I just ended up buying a whole engine for the crank.
Thanks for any help/advise
