rst95eclipse
- 98
- 1
- Feb 23, 2006
Minneapolis/Rochester,
Minnesota
So I have my motor on a stand and I'm prepping to have everything on the timing belt side done this weekend. I disessembled everything off my 2g motor and placed the seperate things in labeled bags on a table. I have a few questions regarding the swap. Please correct me if I'm wrong...
-The 2g motor has a crank angle/position sensor, while the 1g does not use a crank sensor. I'm not familiar with how Magnus states to build a wiring harness. It looks like they want me to connect all three wires from the CAS to the 2g Crank Angle Sensor socket, which wouldn't/can't be mounted on the engine. But how would this work if I can't utilize it on the 1g motor? I think I needs pictures and a good explaination (I'm a visual learner).
-Magnus also states that the tensioner must be compressed manually. What is a good way to do this? My best guess would be to use a vice and put a pin in the tensioner to keep it compressed. Any good suggestions/solutions?
Thank you in advance.
