Could you check these pics and let me know what these are/do?
EclipseTrbo420A
3,427
39
Jan 23, 2004
WhiteOak/PGH, Pennsylvania
These 2 wires are comming out of the harness and arent connected to anything...weird. Got any clue what they do?
This bottom looking this is just hanging there...how aboout it...whats that do. Thanks guys and how possible is it for my 2 solenoids EGR and the one next to it to go bad?
They have 190,000 on them. Thanks
I know where the thing in the last pic goes not sure what it is but its a capicitator or something that works with the starter its located under the exhaust manifold bolted to the block just above the starter on my 420a
This one connects to a wire from the injector harness...I have no clue what it is. This is on my GSX though
On my gst the capacitor looking thing has a little clamp bracket to hold it to the intake manifold right next to the coil packs, and the two plugs are probably nothing alot of cars have extra plugs for various options or for the manufacturer to do something with or maybe to change timing but dont quote me on that.
I know one of those plugs is for turning on the fuel pump with out having to turn the car on. pretty sur its the black one, but not 100% sure. I recently installed a walbro fuel pump reg and injectors and fuel filter and wanted to test for leaks. ran a alligator clip from the plug to positive side of battery
they could be test leads for something, I know my 91 has 1 for the fuel pump and a couple other ones hanging around. Just an idea
Agreed. Although on my car the blue one is the fuel pump check terminal. I don't have a black one right next to it.:confused:
Well as long as they are not messing anything up I have no problem with them there. Should I remount that capacitor to the intake manifold then...mine is just hanging there? Thanks again.
