Cost To Rebuild A 6-Bolt
You can get a complete Top line rebuild kit from slowboy racing for $499 plus a couple of hundred for machine work. The kit includes "Here we offer the most complete basic engine rebuilt kit. We offer .20 over 8.0:1 pistons, rod and main bearings, b/s bearing, freeze plugs, timing belt, b/s belt, and a full gasket set. The gasket set includes a head gasket, metal exhaust manifold gasket, intake manifold gasket, O-rings, semi-circular plug, distributor O ring, valve stem seal, cam seals, thermostat housing gasket, EGR valve gasket, exhaust pipe flange, throttle body, valve cover, water outlet and spark plug tube seals".
I have about $680 in machine work done. That includes boring/honing, polish crank, hot tank, Shot peen/polish resize rods, balance rotating assembly and Mill/service the head with a valve job.
HyperGSX said:
Yes i have searched. How much would it be (approximate figure) to buy a used 6bolt with a boatload of miles and rebuild it to factory perfect specs?
Since you are going to get a good rebuild why not build with MORE QUALITY type parts? Maybe just a 1g/2g bottom and a NICELY ported/polished head rebuilt with better parts.
You should be able to get it back to factory specs for around $1500. Buschur charges $2000 for their stage 1 shortblock and once you get the $500 core back, you're down to $1500.
Send Buschur your core to rebuild and voila, $1500 and the peace of mind that Buschur just built you a solid bottom end.
Are you sure? I always thought it was $2,000 with a $500 core charge. If you don't give them your core, you pay $2,500.
Bleh, that may be. I've always been confused by core charges, and Buschur seems to be high on everything else anyways. So I'm probably wrong :cool:
  • Wanted 6 bolt NT water pipe
    • chrisman287
