6 Bolt Rebuild
J-Rod7069
Mar 3, 2009
Central Valley, California
Ok, so I have 97 Eclipse with a 6 bolt swap and I'm planning on starting a stock rebuild. I plan on rebuilding both the bottom end and the head. So if you guys can tell what else I would need/recommend I would really appreciate it. So far I plan on using the following:
ACL Main and Rod Bearings
OEM Water Pump
OEM Oil Pump
Cometic Head Gasket
ARP Head Studs
Balance Shaft Eliminator
OEM Timing Belt
I need help in what piston domes to buy and what is needed to rebuild the head. Thanks in advance for whatever help and information you guys can supply me with.
]On the head u could use bronze valve guides, throw some evo 8 beehive springs and retainers. On the bottom you can use 2g pistons or evo 8 piston, balance shaft removed. Oem parts are pretty stout.
