Cooling system and power steering?
90Awd_eagle
63
6
Dec 11, 2008
King, North Carolina
My coolant is more water right now however when I drive the car for a good while coolant pour out of the overflow and looks strange.
Then I also have a problem the power steering leaks from the upper line and I don't know how to stop it.
For the power steering youll need a new oring, the dealer has a kit and so does jnz tuning or extreme psi, the coolant looks like maybe some oil is mixing and could be a blow hg if your bubbling or loosing coolant. Do a compression test to see how low the numbers are.
Okay,
I went and got a compression tester and also got a fuel filter cause it looks like it has never been changed. I will perform the test and let you know what I find. I hope it's not a head gasket I just spent a good bit on a radiator and turbo bolts/ gaskets.
I don't have bubbles just when the car is running coolant will fill the funnel.
Here are a few pics I took coolant out of the system and put it in a black cap the yellow funnel makes it look weird
Here is my dip stick looks good to me just changed the oil a week ago.
