cooling feed fitting size
johng96gst
101
Jul 16, 2011
Westport, Massachusetts
After seaching I found one result, I'm looking for confirmation.
I'm finishing up my 6 bolt swap into a 96 gst, it is the cyclone if it matters, and I'm doing the plumbing now, when I relize I'm missing the fitting for the coolant feed. I had extra banjos off other turbos thinking it might be the same (12mm x 1.25- I think thats the right pitch). When I put it up in there it was to small. I saw in another thread that people where plugging with a 14mm x 1.5 x 1/2" bolt. I don't want to plug but is that the correct thread size, and do I get a banjo bolt and matching hard line for that. Or nipple out (like a hose barb) and rubber line.
Thank you.
Well I ordered the 14mm x 1.5 fitting and it is also to small. Is there a chance that this hard pipe might not be the correct one. Is there any models that have a larger than 14mm line for the coolant turbo feed line. Im completely lost.
I found this pick thanks to google.
This is the fitting in question.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
