cooling fans
haji806
Jul 22, 2010
amarillo, Texas
hello
im trying to install t3/t4 turbo on my 1990 laser and i came to this problem that my 2 cooling fans are kinda big.. and idk what side should i buy as far as thinkness, if anyone have any idea it might help
thanks :hellyeah:
your question is what size? you have what side.... measure it and get a slimline or Fal fan. they are slim and provide more flow than stock!
If you get a 90* elbow welded on your compressor housing and rotate it either way up or pointing straight down you can get around the stock fans with your IC pipes and save all that good cooling equipment mitsubishi provided us with. If you don't run or have AC then you can get away with about anythign for fans and radiator, but if you have the AC condensor and are using the AC, high flow shrouded fans (like OEM ones) are the ONLY way to keep the car cool in the heat with the AC on
well im not gonna use ac i took the belt for it out.. but i wanna do 2 thin fans if i can... the cooler the car the better for me specialy when im gonna try to put 30 psi.... i found some fans they r 2.5" depth and another one 3.1/4" depth , i really dont know wich one to get,, thank for the tips guys
