cooling fans and battery light
Ozyeclipse
88
May 26, 2012
Gadsden, Alabama
OK so here's the deal my cooling fans never worked before.
Ive never had cooling issues but for the hell of it I changed out my old fans that seemed to be stuck for another set of used ones that worked fine.
First off I noticed my 30a fuse besides my battery positive had blown. My cars abs equiped so it has the long copper extensions that are bolted down with 10mm bolts, I noticed they didn't have any washers on em btw...got a new fuse installed it and everythings good again.....
My fans work fine now but my little carresel looking light( cooling fans I suppose) and my battery light stay on the weird thing is that when I raise in rpm they dim out but are still visible.
Does anyone know what's causing this lights to stay on and dim out once the rpms rise. My fans work fine my battery stays charged and everything seems normal besides the lights No other blown fuses either BTW.
Ground seems fine both battery and alt are about 1 more month old never had a problem on them...all new belts too
The battery light just stays on and once I take off it dims out but comes back at idle
