Momar
- 111
- 1
- May 31, 2010
Decatur,
Illinois
I have a 90 talon tsi awd. I Just got done swapping the engine out of my 92 tsi fwd into the car. I swapped the 92 engine harness as well. The car is up and running now, but having some troubles with the fans. I installed slim fans as pushers due to space constraints with my setup. I wired them both up to come on with the cooling fan circuit(passenger side). The do not come on.
I have done some testing. They come on if I jumper the relay. so my wiring to the fans is good. I have watched temperature on my data logger climb up to the 235is range and no fans. I tried jumping the 2 wires that connect to the temperature switch in the radiator together and the fans do not come on. I read that they are supposed to but not sure. I also just put a new thermostat in the car just in case because my radiator core didnt seem to be getting real hot. It is now though. If I jumper the fans the car will sit and idle forever and not over heat, but they wont come on on their own.
I have no ac, and the fan wiring from the ac side is not connected. I dont see that this should cause a problem. I also dont have the small fuse box that goes in the drivers side rear of engine compartment. I know this controlled ac fan. I shouldnt need it for just the cooling fan side should I?
Thanks for your help.
