andymoraitis
- 3,241
- 161
- Jan 25, 2004
Utica,
Michigan
I'm looking for some feedback from you guys on changing out my thermostat on my GSX. I'm currently running a 16G on the stock fuel setup and have the boost dialed to 16 psi (tuned by Buschur). My EGT's run fine at cruise (1350) and I never peg the needle under full boost. My goals aren't to turn the car into a monster, but run as much boost as possible, safely, on the stock fuel system. The next group of mods will be a 255 fuel pump and a 2.5" downpipe. Per Dave Buschur, he says that this alone should be good for 18 psi without concern.
Anyway, I remember that on our mid 90's Mustang Cobras, we would use cooler thermostats, or remove them entirely, to make the car run richer. If I were to install a 140 or 160 thermo in my 2G, would I be able to add a little more insurance by making the car more rich? Again, I'm not looking to crank the boost to 20 with just a fuel pump, but provide a safer environment to run 18 on an upgraded pump. For those of you who would recommend bigger injectors and an AFC, keep in mind that an AFC isn't something I want to get into for this car.
Sorry this was so long, but please let me know your thoughts when you have a chance.
On my car iam currently running a 160* thermostat. I just recently installed it. I thought that the car would run a little cooler all the time. On the highway my temp. runs about 150-160. the thing is that when im at a drive thru. My temp runs up to 200-210. after that I start seeing vapor come out of the hood. (keep in mind i installed a radiator, coolant hoses, 160 therm., 50/50 mix)which makes me turn off the car or just get out of the line as soon as possible. Well i figured out my problem. on the highway there is more air (duh) and the thermostat is staying open which allows the coolant to stay colder. At the drive thru the thermostat stays open all the time because there is no air getting to the radiator. So what happens is the thermostats open and the fluid is constanly resirculating around the motor and the radiator. Because the thermostats open, the fans do not get a chance to properly cool down the fluid as it passes thru the radiator core. its sort of like running no thermostat at all. only on the highway. youre best bet is to run a 180* thermostat so that it does hold some coolant in the radiator and you can get some type of cooling to the motor.
