- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- K&N Intake, 3" SS dp, HKS Hyper exhaust, Evo 3 16g, Hallman MBC, FP 255lph, STM fuel pump rewire kit, STM tank to rail -6 kit, STM FP regulator kit, MSD wires, Greddy RS bov, Greddy timing belt, AEM black cam gears, Zaklee clear cover, Samco hoses (camo), FP ex manifold(Nitro Plate), FP intake pipe, SS 02 housing, FIC 1050 injectors, Punishment FMIC, EVO 3 intake manifold (ported), 70mm S90 TB, Magnus intake gasket, ARP cam 02 housin exh. manifold bolts, powder coating done by Detective Coating
- Mods-Engine
- 6 bolt block, 7 bolt head,Wiseco 8:3:1 std pistons, Total Seal 2nd ring (x8674), Eagle H-beam rods, ACL tri-metal bearings,BSE kit, OEM MLS head gasket, ARP head bolts, EVO springs and retainers, GSC S2 cams, Top-line lash adjusters, -8 oil catch can, machine work done by Longs Machine Shop
- Mods-EMS & Logging
- Ecmlink V3 full, Kiggly crank trigger sensor, AEM wideband, Autometer gauges CF oil, boost, water temp, volts
- Mods-Drivetrain
- Stock 2G awd trans, South Bend SS-TZ clutch kit, OEM throwout bearing
- Mods-Handling
- Stoptech slotted rotors F/R, EBC red stuff brakes F/R, Earls SS brake lines, Tanabe DF210 springs, KYB gr2 struts, Ingalls camber kit, Torque Solutions driveshaft bushings, Prothane engine mount inserts, Energy Suspension bushings, Godspeed FR sway bars, Sparco Speed 2, Wedge Brackets
- Parts Wishlist
- FP turbo
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
