cOOLENT LINE help!
AWDGUY86
101
Mar 8, 2004
Plainfield, Illinois
aNY ONE KNOW IF THE COOLENT LINE THAT RUNS FROM UR STOCK OIL FILTER/ COOLER WILL WORK WITH THE 50 TRIM, ALSO i CANT FIGURE OUT HOW IT IS SUPOSE TO GO i NEED HELP asap! :confused:
Let me suggest a couple things to get your question answered.
1. Try not typing in all caps
2. Try proper spelling.
3. Lets get a little more detail.
Which 50-trim do you have?
Exactly which line are you talking about?
dude, first calm down. Second, caps dont help. Third, why would a coolant line come from the OIL filter housing? You need a stainless steel oil feed line that many of the vendors sell, and a new oil return tube as the flange on the 50 trim is different. I would call force performance, they have a return tube that isnt all metal so it wont have problems cracking in the middle like mine did. Its not that hard, calm down and use common sense.
first off i am calm but im not talking about the lines going to and from the turbo i am talkin about the line that runs behind the turbo to the oil cooler and the top radiator hose area I cant get it to fit.
reread your first pipe, how is anyone supposed to know what you are talking about. The "coolent line" you are talking about is the water pipe that is in front of the block. It doesnt run to the oil cooler. Its in your way, so you must dent it in and rotate your compressor housing. You can ask for help, but you cant ask people to read your mind. Well thought out and detailed questions yield much better answers.
