14b coolent lines criss crossed return and feed
dsmking101
224
May 13, 2009
????, Utah
Im having this problem with my antifreez for some reason i had the car on for about 20 minutes and had the heat on blast but no heat.. The car was not over heating and was idleing fine. Its bin sitting for about 2 months but started up fine. I removed the radiator cap and it shot up at me with a hole lot of steam..
My question is i just put a new 14b turbo on my car and was wondering if i had the coolent lines from the block crossed going into the turbo. Is there a return and a feed for the coolent lines on the turbo or can they just be put on anyway...
This never happend before so thats the only thing i can think of right now is that i have them crossed...thanks please let me know asap any info will be nice.
Sounds like you maybe never got it full of coolant or you have an air pocket. Let the car cool and fill the radiator and overflow reservoir with coolant and leave the cap off the thermostat housing. Start the car and run the heat on full blast. Let the car warm up and watch for the coolant level to go down in the thermostat housing. If it does, fill it back up. After it is fully warmed up and you are sure the thermostat has opened you can top it off one last time and throw the cap on there. You should now have heat. If not you most likely have a clogged heater core.
