Coolant pooling between throttle body and valve cover
jrrrd
Jan 15, 2003
hey guys,
no oil in the water. i suspect the water lines going to the underside of the throttle body, however the friggin thing smokes so much that i cant get a good look at where the leak is any other ideas? not a consistent leak seems to only leak once the system is pressurized....thanks in advance :)
You could try to pressurize the system manually and check that way. I think AutoZone has a pressure tester you can rent.
