Coolant Leak - Update!
majik2k5
799
18
Jul 13, 2005
Lemoore, California
Alright, so the oil filter's changed and the line that blew going to the oil filter housing was fixed. But when the coolant was put in, it leaks right back out. I can't see where it's coming from, but there's still no heat in the car, and it's dripping from around the crank pulley.
I managed to get some pictures. Any ideas?
Could this be the block or the head? It had oil right around that area. There hasn't been any oil put back in the motor yet since it was drained.
Id say check around the oil filter housing again to see if you can see if its comming form there. ID also check around your water pump and water pipe to see if any leaks are comming off there. Id totally also recommend from your pictures to get that axel replaced.
