Control Arm Bolt MB844523
dsmgsx97
May 3, 2004
leesburg, Virginia
Does anyone know where I can find part number MB844523? It is the 12mm x 160mm bolt for the rear front lower control arm on the inside that connects to the sub-frame. Rockville Mitsubishi, mitsupartsdirect.com, says that the bolt is no longer made by Mitsu. I have also tried http://www.mitsubishi-parts-dealer.com/parts.htm with the same result. I "really" the two of these bolts as my lower arms are frozen like so many others and I have already cut them out. Any help is appreaciated and yes I have searched up and down for the answer already.
Thanks,
Ian
