conquest ic on a dsm and bad idle
ktg-dsm
Jul 21, 2004
akron, Ohio
I have a 91 gsx and the idle bounces from 1500 to 2000 rpms any STRONG ideas on what it could be? Have been told it is a vacuum leak and the ECU. I also have a conquest front mount and would like to know if there is anywhere that make IC piping for it or if I should just sell it and get a different one? :dsm: :barf:
easy thing to do is make a leak tester. im sure you'll find a leak somewhere.
also check your ISC motor, it's easy to test too (vfaq.com)
make sure there is no air in your cooling system.
keep trying, if you have my luck, none of those will fix it.
