compressor outlet gasket question
yeti-gvr4
422
Dec 23, 2010
san diego, California
Do I need to put rtv or some kind of sealent down when torquing the j pipe back down onto it?
im preety sure i do...can anyone point me in the direction of which color or a link to a brand name?
There is an actual gasket for the j pipe if you want to use one (I would use a gasket personally). Permatex for a sealant brand.
i know about the gasket just bought OEM one..
q was about the sealent
thanks 4 answers and sorry for confusion
is the permatex copper color good or should i get red (copper is good untill 700degrees
The gasket is providing the seal required, otherwise it would be pointless to use a gasket. If you truly wanted to use sealant on there as well, put a VERY THIN layer on each side of the gasket.
good 2 know thanks alot il just use the gasket should i follow torquing procedures or just torque the hell out of it
