compression test
Turbizmo
430
Jul 3, 2005
Salinas, California
well my friends car is a 99 420a turbo and i did a compression test ### it was trowing to much blue smoke from the exhaust and i though 1st the turbo might of had some broken seals but it brand new so we decided to do a compression test and these where the numbers
1 cylinder = 80
2 cylinder = 150
3 cylinder = 70
4 cylinder = 160
my question is. Is the head gasket broken? also would we have gotten different results if we had the foot all the way down on the gas pedal and cranking it because we only where cranking it?
You should be doing a compression test when the motor is fully warmed up. Disconnect fuel and spark and crank at WOT until the compression no longer increases. I would be betting on broken ring lands on both of those pistons. But its prossible it could be the head gasket. When I broke the ringlands on the stock pistons I had exhaust coming out of the valve cover when I took the oil cap off so you could try that to.
Compression test with engine warm and throttle wide open, as mentioned already.
To get a better clue, perform a leak-down test.
ok thanks i will do that soon and ill let you know what the numbers are
  • For sale NEW Magnus Forged Transfercase gears PENDING
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
