compression ratio
safirenside
170
Jan 28, 2011
houston, Texas
Ok so I have a question sine im changing the stock compression ratio to JE 8:5 I was wondering if i would need a tune. In a later date I paln to turbo and get megasquirt but for now it will be a N/T.
Isn't stock like 9 or 9.2:1 for the 420a?
You would not need a tune, but you will probaly notice a difference in regards to less off line power.
No need to wait for the turbo to wait and build the motor. Built the motor now and break it in some (even tough breaking in a motor is a myth) I dont break them in nor does buschur. I drove my 8.8:1 motor unboosted for like 30 miles then i cam across a turbo kit for a decent price. I have been boosting 12 psi since 250 miles.
It's not a myth, man. There is plenty of research to back up proper engine brea-ins. A lot of time the damage that is caused is microscopic at first, but it's been proven that the initial wear caused to the cylinder walls and rings during the break-in period can be drastically reduced with proper techniques and/or the use of certain additives such as ACES.
You can't tune our ecu's. They are not Eprom or reflashable. If you want more from an NA motor, the AFX ecu will give you a boost. I would save the loot for a MegaSquirt system, though. That ECU is tunable till your heart's content.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
