Infiltrate2000
- 172
- 2
- Dec 27, 2003
QUEENS,
New York
Did compression test on 98gsx. getting about 135psi across all over after 8-9 cranks. Weird thing is i keep cranking, the compression will go up to about 180psi and then stop. I was always told to do test with 8 cranks.
My question is, any reason why the number is going up with more cranks, especially reaching 180? I seen cars with bad motor, and the compression almost never reached such a high number no matter how many times you crank.
