Compatible shift cables for 97 eclipse spyder gst
Dellesz
Apr 14, 2014
Boise, Idaho
Hi guys im getting ready to pick up a 97 eclipse spyder gst. I have a wrecked 1g and i was wondering if the i could use the shift cables off of it? i do have the tranny off the 1g so i can swap the levers if need be, or the junkyard has plenty of 2g gs would the shift cables work off that? i cant afford to buy new ones but im getting a really good deal on this car. So there is no way im gonna pass it up. So just trying to find compatible shift cables. Both the 1g and the gst are manual. Just that one is a 1g and one is a 2g.
I know the shifter brackets on the transmissions are different, but as far as the cables go, your best bet would be to compare them to each other before swapping them. You could however use any 2g turbo DSM cables or even the cables from a non turbo spyder.
