colder spark plugs?
sillyme
151
Aug 3, 2005
seattle, Washington
i put in NGK 7 instead of the 6's (during dyno tune) and now i'm driving it daily and feel kind of off. there's a slight miss at idle and i notice the afr is going lean more inbetween shifts. is this the colder plugs fault?
i got the same prob i think but mine original plugs were denso irridiums had them for 2 years ran fine when i changed them out for ngk it started to give me idle problems should i go back to denso??
I agree with Defiant. In theory though, you shouldn't need the colder plugs without bigger mods. With our cars (420a), we only need to go a range colder with the addition of turbo or nitrous.
Hello, I changed from 6es to 7es NGK...three days ago, I did some research and it is best to go one step colder if boosting over 18psi, or if you are sensing detonation/ knock...I have no issues after the swap, I did gap all plugs to .028. Hope this helps!
