clutch the same for fwd awd 6bolt 7bolt?
Yep, the flywheels are different though :)
So basically if I have a 2g I can drop a 6 bolt in there with a 6 bolt flywheel and be done with it? Or what else do I have to do? (yes noob question)
Correct. The things that are different are the flywheel (6 bolt vs. 7 bolt and FWD vs. AWD), starter (FWD vs. AWD), and starter plate (6 bolt vs. 7 bolt).
Make sure you keep your 7 bolt starter plate when you do the swap. Then put in your 6 bolt flywheel and whatever clutch/pressure plate you want. Make sure to get your flywheel step checked before installing.
