Clutch Replacment
Yoshi
53
Jan 5, 2006
Richmond, Texas
well my clutch is shot.... :cry: but i was wondering if the slave cylender needs to be changes along with the clutch?? because if i do change it that a extra $100....
not sure... but my car does have a oil leak and i have no clue where its comming from but its somewhere behind crank plate i think is what its called
If its not broke, don't fix it. I never heard of any kind of upgrade for the cylinder...
Doesn't sound like its leaking so you should be good.
well my car's leaking something looks like oil... and i have no clue where its coming from soo tomarrow im gonna take some pic's of where the oil coming from so yall can help me out
Clutch fluid is DOT 3, same as brake fluid (clear). So it should be easy to tell this from an oil leak. Also your resevoir would be low or even empty. So sounds you like your oil leak is a seperate issue.
