Clutch replacement, what else to change?
blazebolt
392
20
Jul 29, 2005
San Jose, California
I'm going to change my clutch/flywheel and have my tranny rebuilt. With the tranny out for rebuiling, I'll have some time on my hands and might as well replace everything. I already have SS clutch lines and a relatively new slave cylinder. I'm going to replace the clutch for and pivot ball. Is there anything else I should change with the tranny out?
Thanks
Throw out bearing... Grease the input shaft that the TOB rides on. I would replace the Fulcrum ball (pivot ball). Clutch fork really isnt necessary but if you want to you can.
Make sure the flywheel has been resurfaced or brand new, locktite on the flywheel bolts is a good idea. Remember to torque everything down and double check everything. It gets to be a pain in the ass to have to keep pulling the tranny because you forgot to do something.
Good luck!
OEM!!!! A lot of people have had trouble with the ACT TOB. Some say its OEM but I have reason to believe otherwise.
Oil pan gasket can be done with tranny on. If anything, replace the rear main if leaking. I wouldnt mess with anything that isnt bad "yet". Like the saying goes, "If it aint broke, dont fix it."
While the new ACT TOB's should be their plastic lined version, I've still seen several posts with guys having issues with them. Go with an OEM TOB, the extra $25 is a whole lot better then having to pull the tranny again in the near future for a faied TOB. Here's a complete list of what all should be done, the tranny's out so may as well do it all now so you know your good till the next clutch change. Like I said its better to spend the extra now instead of having an old part fail & have to do it all over again.
-Mitsu TOB
-Fork
-Pivot Ball
-TOB Clip
-New Flywheel Bolts
-Rear Main Crank Seal
-2 Tranny Diff Seals
Not sure if there's any seals to do on the transfer case while your in there, as I don't have that issue :cry:
inside the TOB is a inset ring, you load that up with high temp grease, put a coating on the sleave the bearing rides on, do the input shaft splines, the area the clutch fork contacts the TOB, pivot ball, slave rod to fork contact, and slave rod to slave will need some more grease probably.. also grease the t-case output shaft splines, check for a leaking transfer case yolk, fix if necessary..
Good call on the fuel pump.. I did mine while I was in there too..
Here's some OEM part numbers
OEM output to center dif seal MD723202
OEM input shaft seal MD741818 - don't bother with this, you need to open the tranny up as I found out.
OEM left front axle seal MD719710
OEM right front axle seal MD707184
OEM clutch fork MD770506
OEM pivot ball MD719602
OEM TOB MD749998
OEM TOB clip MD706185
I just used some high temp lucas grease I picked up at good ol' canadian tire.. just get some name brand crap that's ~550F+
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
