Clutch Rattling
Klobbernator
Mar 3, 2012
Meridian, Idaho
I feel like the further I go with this rebuild, the worse it gets! :thumb:
So I got my wastegate fixed (forgot fire ring). Car spools amazing now. Fixed my vacuum leak.
Now I can hear a terrible rattling noise, sounds like lower engine/tranny. The motor is fully rebuilt, maybe has 5 miles on it. Oil psi has been between 40-80 depending on temps.
I did put a new TOB in there, but did not replace the fork or clutch. Is this most likely the clutch assembly? It's definitely not rod knock. Changes tone/volume when clutch is engaged. Let me know if a video would help. Thanks.
A video would help a lot. Did you install the clip that holds the tob to the fork? Did you use the right length flywheel bolts, and did you torque them properly?
I did tons of research on the clip, and believe I installed it correctly. I bought new arp flywheel bolts and torqued them to spec in the manual.
