Clutch Problem
BoostNV
69
Oct 29, 2002
Ok This has happend once before but I can never duplicate the problem until this morning..I was driving to work and I stopped at a light when I went to take the clutch pedal stuck to the floor. It disengaged the clutch but the pedal stayed on the floor. I pulled over reached down and popped right back to normal and I couldn't get it to stick again.
I have a TRE-Spec transmission the an ACT AWD flywheel and a 2600 clutch. Can anyone give me ideas of where to start looking for the issue or what the issue might be?
Thanks
this same thing happened to me. scared the shit out of me because i thought i had messed up my clutch fork. for me it was the clutch accumulator. its bolted on to the tranny with 3 bolts. check the slave cylinder then ckeck the lines all the way back to the master cylinder if there is a leak then you'll see it.
Check out road race engineering's site, it is your master cylinder. Its a little o-ring that is bad, but its easier usually to just buy a new one.
