Clutch pressure issue
Daveregs
98
Apr 26, 2014
Waterbury, Connecticut
Hi what's going on guys. So I'm having Alittle bit of a clutch pressure issue. Intermittently I lose my pedal. It goes straight to the floor while driving and obviously notice it when I go to shift. Once this happens I let up on the pedal and then engage it again and have a pedal. I'm not losing fluid and I bled the clutch last weekend. Possibly bad slave cylinder or master? Any thing I can do to test the hydraulic part of the clutch?
look for leaking fluid around the slave cylinder and look on the adjustment rod for the master for leaking fluid. First check if your fluid is full
As I said already I'm not losing fluid. And not seing any leaks anywhere
Is it true these car have slave cylinder issues?
Found the issue. Ended up being my clutch pedal adjustment actually. I adjusted it about 3-4 full turns and now I have a strong pedal and clutch catches right in the middle. Problem solved! Just in case anyone else has a similar issue
