Clutch pedal problem.
eder-loco
133
Feb 19, 2006
pasadena, Texas
So i Am having a weird problem. Whenever i start my car in the morning, clutch pedal feels kind of soft, Goes into gear just fine. But the more i drive it starts to harder up. but still goes to gear just fine.Clutch engagement does go up, away from the firewall as it get harder.
When its soft right after i star the car,the disengagement of the pedal is like i had it. a bit off the floor.
my slave cylinder is new.
Master cylinder does not show any leaks if i look down at the firewall.
any ideas?
it sounds like you just have to bleed the clutch a little more... if pumping hardens it up, then there are air bubbles in the hydraulics
Similar thing happens to me. I'm not really sure if it's a problem. I'd always assumed it was just the fluids getting worked around.
