Clutch pedal goes to floor when reving?
1gDSMike
94
Nov 21, 2008
Portland, Oregon
I can't find anything on this.
pretty simple question.
Yesterday i just randomly decided(never have done this anytime before this) to go ahead and redline it, as I'm doing so i have the clutch pedal pushed in. When it gets up to 7k the pedal literally gets sucked to the floor??
Anything on this, if its bad. LTM
thanks:confused:
Yes i was just sitting, and i did just notice today the clutch master cylinder reservoir is half empty non the less go look under the pedal, bam tons of fluid. WTF. This is brand new. Hmm going to take it in and get another i guess. My clutch has been disengaging about an inch off the floor for awhile now. :confused:
Just got done with this type of problem:
Your losing your fluid pressure which is why the pedal stays on the floor. Check all your lines for leaks, check your master cylinder and your slave. If they are both stock and you have high miles, you may wanna replace them anyway.
Let us know.
LIke i said i just did my master and slave, ran into some problems that were a PITA. So ill have some advice if this is the problem.
