Clutch pedal connection to master cylinder.
90 GSX
322
Jun 24, 2004
Fremont, California
I bought my 91 talon with no clutch master cylinder. I got a master but I can't figure out how to connect the piston to the pedal. Is there a clip of some kind that holds them together? Or does the piston clip on to the pedal? If anybody could describe it that would be awesome, it's for a 1991 talon tsi.
You've got to look all the way over past the gas pedal. Just follow the bar that the clutch pedal is mounted on to the other side of the assembly. There should be a pin that goes through and a clip that goes on the end. It's all but encased in a metal frame and a total pain to get at.
