Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
How much under-dash pain do I have to go through to replace the clutch and brake master cylinders, now that they are at this point? (see pic below)
The firewall is going to be cleaned, filled, and sanded; should I pull the brake lines off at the front calipers and remove them and the proportioning valve on the firewall as well? (I may go with SS lines anyway). I'd also like to get the vac booster out of the way for painting if possible.
How much of a pain will it be to get brake fluid all the way back to the calipers and bled if I pull all of this?
... guess you didn't see
