Clutch line leaking.
JMiller
684
Jun 30, 2007
Irmo, South Carolina
I just replaced my master and slave cylinder because one of them were leaking, and they were old. Well after i replaced them and adjusted the clutch pedal it ran good for like 2 days and then the pedal got real loose and then i couldnt put it in gear at all. I bleed the system multiple times but when i was under the car today i relised that the line that connects to the banjo bolt on the slave cylinder is leaking. Its as tight as i can get it without stripping the bolt. I was wondering if anyone had a suggestion as to how i can fix this. Thanks.:dsm:
Its not the actual banjo bolt that is leaking its the line that goes into the banjo bolt. (The new slave cylinder came with a new banjo and washers). The metal line that also connects the that resivoir thing in front of the trannsmission. I was thinking about about switching to a ss line that replaces that metal line the resivoir and that rubber hose, but i cant get that right now, and i need to use my car. So i was wondering if there is some way to get it to stop leaking for like 2 weeks until i can get the ss line. Also its leaking from the thread part, ill post a pic to specify in a few mins.
Not to bring up an old thread but i need to find a fix for this i have same problem but there is nothing at autozone to fix ths please help
