Leaking Clutch Fluid
elements
Aug 9, 2003
Sounds pretty simple...
Started a month or 2 ago, the clutch started sticking and then got stuck in 2nd gear. Opened up the cap, and no clutch fluid, filled it up and it was good for another 3 weeks or so, but now it happens to where the fluid will be gone in a day if i fill it up again in the morning. No spots on the ground where it leaked out, cant see it leaking... any easy ways to fix this problem? Is the clutch shot, just a leak in the line or what?
Thanks
you cant see it on the ground cause all the fluid is in your car ! haha look under the dash driver side at firewall. When the Master cycl leaks it leaks inside the car. Its not hard to replace just a PITA.
solution : Replace master cylinder , bleed system , dribk a beer :thumb:
