Clutch Line fitting siezed and now rounded!
Attack Eagle
1,330
16
Nov 1, 2003
El Paso, Texas
Apparently when the last 7 bolt went in at the dealer they must have grossly overtightened the brass clutchline fitting.
Even with a line wrench it just rounded off.
At this point I jsut have to ahve ti cut off and replaced with a new fitting? Correct?
I was trying to remove it to fit my SS clutch line I got from RRE, but that is now impossible.
I tried everything but a pipe wrench (clearance too tight).
What size fitting do i need, or do I jsut take the car and the line and say... here, new fitting?
Tried visegrips yet? I know on a 1g its a tight fit, but I was able to crack a friends line loose with a pair of visegrips.
I haven't tried vise grips yet... that will be my last chance to get it off and back on.
and DEFIANT
it's the UPPER fitting... non removable from the car.
I wouldn't bother you with something like a slave fitting (which is a banjo bolt anyway)
sorry, I always think of the other as a banjo bolt... not a fitting
