Clutch issues need help
Tyme Carrot
Nov 7, 2010
Milwaukee, Wisconsin
So I took my car to a local shop by my house to have my clutch done because it was grinding in and out of gears. They took my car for a month and gave it back to me with a new pedal assembly, lines, clutch, flywheel, master cylinder, and slave cylinder. That was in march.
Now my clutch is acting up again and i cant figure out what it is. It catches about a centimeter off of the floor and sometimes when i take off it will stick to the floor. the only way i can get it to come off of the floor is to let off the gas and pump the clutch a couple times.
Has anyone else had this problem? I also got under the car and noticed that the slave cylinder is for a fwd and i have a gsx. Could that be the problem?
sounds like you have air in the hydraulic line for the clutch. autozones website says the awd and fwd slave cylinders are different. just a thought
I adjusted the master cylinder rod out as far as I could without closing off the bleeder valve for the slave cylinder. Im going to get the slave cylinder for the awd version and see if that helps. Should i replace the mastercylinder too? I just had it done in march but I hear you should always try to do it at the same time
