Clutch install No tranny fluid
baker838838
Nov 17, 2006
kresgeville, Pennsylvania
My clutch started slipping about a week ago so bad it wasnt even driveable. So I ordered all new parts and started getting to work. When I went to drain the tranny fluid there was almost none. probally a quater quart would this cause the clutch to slip bad enough not to drive? Please HELP! thanks
Nope just like defiant said, you're clutch/disc/and flywheel are all closed off, im sure you will find out when you replace them. Check all you're fluids and make sure your master and slave cylinder are in good working condition, if you plan on keeping the car, you misewell replace both since the car is 10 years old and exposed to alot of salt and snow in P.A.
