2G Clutch Hose?
Blakedwight4
58
4
Aug 5, 2023
Camanche, Iowa
Hey guys. My clutch slave cylinder recently went out so I am replacing the master cylinder, reservoir/cap, ss line, and slave cylinder. I am trying to also replace a rubber line that was referred to as clutch fluid return line? I have gone to parts stores and they have no clue what I am even talking about. I have read that the only hose material suitable for clutch/brake fluid is "EPDM" hose. Has anyone else ran into this issue or replaced the line with fuel line or something like that? I don't want to just rush into this and want to do it right the first time and hopefully not have to mess with it again for a while... I have found the part on mitsubishi motors, but its discontinued I believe. The part is pictured as "20025". Thanks in advance!
They just let me come to the back and look at what they have and it’s not a lot. And I’m mainly wondering if EPDM hose is really what I should be after or just be searching for 3/8” brake hose.
Any brake hose you find is likely epdm. This is one example.
