clutch has no pressure?
Eclips3
Mar 30, 2004
cinti, Ohio
i recently had my clutch bled, as well as the head gasket changed blah blah blah... anyways, yesterday it had pressure, but it would sometimes get stuck close to the ground, the other times it would be fine. dude at the shop tht did the work on my car said my clutch line has a kink in it. but dumbass me i dont know where the line is. i just got this car not too long ago so im still learning where everything is just about. so i go to start it today, push the clutch down to start it and it starts, but the clutch pedal goes to the ground, and i am able to pull it back up. . . is it possible that the clutch still has air bubbles in it and needs to be bled again? im stuck here guys. plz let me know!
wow.. i think that its the air inthe line man.. thats ur prob. go buy some DOT 3 fluid and bleed ur clutch. itll b back to normal, jus make sure u get all the air bubbles and nasty fluid (if any ) out.
yes i will try to do this again 2nite. a friend is going to help me. i checked the vfaq's or whatever section on here and i found an article...
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=60319
thats exactly how you do it? but i dont have any vaccume hoses to do that with.. and i bought some hydrolic clutch fluid. good enough eh?
