spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
I know there are MANY clutch failure threads and I don't know if the same issue is out there, but I'm sure it is, but after several looks, I'm finding mostly the same issue not related to mine. Anyway, as you can see...
I have a major gap between the slave cylinder rod and the clutch fork. This past Saturday, I replaced my slipping clutch disc. Everything went back together and my car drove perfectly. No issues. Sunday, I let my fiance take my car as her car needed a new tire. I later had to move it and it had no clutch pressure. I assumed this was a fluid bleeding issue and have bled the system many times since Sunday only to get nowhere. The pedal builds pressure when pumped, but after letting the pedal go for a moment, it losses pressure again. I now see that it wasn't a bleeding issue and it's this gap. What is the most likely cause? My guess is that the TOB could have gone out, or maybe the pressure plate fingers. I can get my car to start, and I have gotten it to shift into 1st and reverse when I moved it with the soft pedal, so I know that everything engages and works, so I'm confused and want to know what I can do to find out before I tear things apart yet again.
