clutch engages to quickly after act 2100 install
xcelr8n
1,854
5
Jan 31, 2003
toronto,
hey guys I need some quick help here.
I finished the 2100 install yesterday, new kit, tob, flywheel, everything.
only issue is that when you start off in first gear the clutch grabs WAY to low, I even stalled it a couple of times.... :laugh:
anyways i'm guessing it needs to be adjusted? thanks
oh and btw shifting and all else seems ok..
new clutches engage lower and then get higher as they wear.
plus going from stock to 2100 will give you a little jolt. :)
I just finished up my ACT 2100 install this morning. I bled the system, cranked up the car and found out that my clutch engaged 1/2" from the floor.
I jacked with the adjustment on the clutch pedal and got it to where it engages around 1"-1 1/2" off the floor.
I damn sure second the fact that when I shift to second its a bit more jolty than when I had the stock clutch on 3 days ago.
Try adjusting it some more, it worked for me. :thumb:
gsxtacy
gsxtacy
this is 100% exactly how my morning went, engaged right off the floor half inch at most..
adjusted it somemore, $%^& that adventure, anyways seems as it should now.
thanks guys
    • Sdcryan1
