clutch disk question
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
does anybody saw a six puck clutch disk without those little springs?! are those clutch disks are any good?
and the second question is: could the clutch transfer alot of vibration into the body??? because i got prothane motor mounts.i know that the poly mounts are causing some vibration into the body,but the vibration that i have its really big, i can't even hold a steering wheel.Between the shifts vibration is going away for a sec till i hit another gear,as soon as i put the gear in the vibration comes again.
Sure. There are 2 kinds of puck discs. Sprung and unsprung. Sprung offer smoother engagement, unsprung offer a harsher engagement. I would not recommend an unsprung disc for street use. I have a ACT 2100 with a 6 puck sprung hub disc with an ACT flywheel and I love it. It is a little annoying in heavy traffic because you have to slip it, but on a normal day I can't tell the difference between my older stock street disc and the ACT 6 puck sprung hub disc.
You'll feel your engine a lot more with all prothane mounts, so when you shift, you'll feel the vibration from the engine bay. You could go back to some stock mounts and just leave lower prothane mounts in your car. I have Energy Suspension lower motor mount inserts on my 2G and the vibration is not that bad. Try bumping up your idle, that may help.
today i found out the problem.
the problem was ,that the bottom tranny bolts were unscrewed half way down,so i tighten them up and that horrible vibration gone.but i came up on some other stuff.does the slave cylinder rod suppose to move easy or hard? because i tried to move it but i couldn't move with my hand? is that normal?
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
